Your best budget move is to build the 360. Use a set of magnum heads and kb107 pistons to get compression up. It will have no trouble making 400lb ft of torque at a lower rpm friendly to towing. 360 with piston change and magnum heads will be much more efficient than either of the smog 360/400 motors you have now.
