still hitting part of the dr motor mount if i want the engine centered in the bay. big issue now is oil filter hits k member before the engine plate sets on the frame rail. looks like an inch to go before the plate will sit down on the frame rail. using a milodon oil pump and im guessing its thicker than a melling. would appreciate some input if anyone knows how to make this BB with engine plate fit an A body K member. thanks
