floats are correct I am assuming (level dimention/not waterlogged/linkage free). might need new needles/seats (available seperately & are cheap). fuel PSI might be too high (common with eddys). what is your initial? EDIT what is the vacuum? baseline rods/jets in there I am assuming. Almost forgot the most important one: rods being held down steady at idle?
