I would use that in a heartbeat Have fun degreeing the cam
Degreeing cams is easy. Put cam in, and find intake lobe max lift (Centerline.) Lock cam in position, or at least mark the cam gear to block position. Install degree wheel, find TDC, and zero degree wheel. Rotate crank so degree wheel reads the installed centerline you want. Install timing chain or idler gear without moving cam or crank position. Done.
