I have a couple unused Callies cranks. 2.93 stroke and 14 Carillo rods. Also have an ATI damper. The cranks were cut on the snout for dry sump so a spacer would have to be made for the pump drive. Some trouble but I would sell the crank, 8 rods and the damper for $750 + shipping. The damper would need a different center or the existing one cut to remove the dry sump pump belt drive.
Was for a 305 project that never went forward.
