Only a few suppliers out there that make the filter. Any name brand is fine. The 48 came with a reuseable pan gasket - a plastic backbone gasket with rubber beaded seals. The best gasket out there. I would reuse it.
Stay away from cork or that other garbage. And NO RTV is needed. I would use any name brand ATF + 4. Don't use dexron, mercon or F in any Mopar OD unit if you are towing or hauling.
