I went with crown vic brakes front and explorer rear, the explorer rears were the same size piston as the crown vic rears. installing the fronts on standard drum brake spindles and hubs with the rotors that fit perfect. Took a while to find compatible studs, but should be a simple upgrade because ford already did the engineering for me. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
I didn't do 4 years and 9 months of Graduate School to be called Mister!
