When I had trouble with my front end,I installed
problem solver bushings-still not enough. So I shortend my strut rod to pull the control arm forward. Did a garage floor alingment and the car drove great. A couple years later I wanted more caster so I bought tubular arms anyway. Mike
Where you using the poly strut rod bushings? Those are thicker than stock by about 3/16". I shaved mine 3/16" in addition to running Moog 7103 offset bushings. How to here: http://users.erols.com/mathewg/bushings.html
I can get 5-6 degrees of postive caster if I keep the camber under 1/2 degree. I ran 1.5 negative camber this time and only could get 4.3 degrees positive caster.
What caster did you have before the tubular UCA's? How much now with the tubular UCA's.
