Yes I thought about that and will go that route if I can't figure out how to mod the control arms. I really like the difference in poly compared to rubber and hesitant to go back to rubber. Thanks for the fast reply.
The lower control arm take most of the loads. Getting the right performance alignment will outweigh any difference you feel or performance of the polys. You can't even get to the spec alignment numbers.
You can just take a 3/8" to 1/2" section out of the rear A-arm leg and pie slice the front leg then weld. Then overlap with some steel for good measure.
