What kinda power you think I'd get out of this set up? I was looking and it seems like it's around 500 horse but not sure, anyone have a better idea?
You won't know how much power the motor will make until you run it I have made 430 HP with a mild 440 stock 446 C.I. iron headed pump gas street motor with a six pack on a DTS engine dyno. I have also made 535 HP with a 451 C.I. 440( .055 over bore) motor with ported big valve pump gas iron heads and a lot bigger solid lifter camshaft with a single 850 Holey D.P. carb. Cam timing, jetting, exhaust system and a bunch of other things end up helping or hurting how much power a motor can make I've seen 80 HP loss and gain by changing the cam timing(going from 5 degrees advanced to two degrees retarded) on a engine dyno test The 4.10 gears in that car will make you wonder were all the power came from Drive it first with the 2.76 and then the 4.10
