The mech sec 450 Holley #9776 is not a double pumper The lean tip in has to be covered by the single pri acc pump.
Really their not double pumpers? It's nearly the first thing on the box they're sitting in, in gray bold "double pumpers" but I could be wrong, I'm not sure cause it is the #9776. Can you send pictures on here?
Don't check the box, check your carbs. If they have accelerator pumps in the front & rear bowls they're double pumpers.
I love the smell of Deer guts in the morning, it smells like... VICTORY!
