I'm in the process of changing over to rear disk brakes on my 69 GTX 8 3/4.
Car has Moser axles and green bearings.
I installed one side and it went great, tried to install the other axle on the other side and it stops about 1/4" from seating.
Guess the backing plates and gaskets must add up to 1/4".
When I installed the green bearing I must have left the thrust block in the center section.
How do you remove the thrust block??
It is a cone style 489 center.
It would be easy to machine the axle length down .125" per side, but they are newer axles and would this voide any warranty with moser??
Should I just pull the pig and get the thrust block out of there?
Thanks for any help guys!
Ed
