Hi,
I'm trying to determine the difference in wiring between a 1971 B-body two speed wiper switch and a 1972 B-body two speed wiper switch. If anyone has the 1971 wiring diagram, could you please respond with a scan or picture?
I know the two speed switch is different between the two years, but need to know if the wiring to the bulkhead is the same. I don't know if the wiring from the bulkhead to the wiper is the same.
Thank you,
Mike.
