Originally Posted By Bigcube
Yes, the car will be killed when you flip the switch but the wire will be hot all the time. The relay prevents that.
Guess I dont see the issue with it being " hot" when the car is turned off. The battery is " hot" too when the car is turned off. That's like saying a light switch is hot when it's off, because power is still at the switch.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight
418 BPE factory replacement headed stroker, 565 lift solid cam
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
