I am going to drop the driveshaft tonight and see if there is any difference. As far as transmission is concerned I know for sure I am going to be spending some time adjusting the linkage. Gears were hard to find during test drive and won't stay in gear unless shifter is held in place. Again, since the car was never driven since built, I figured there would be a few bugs to work out. Just trying not to break something expensive right off the bat. When up on jack stands I must restate that I had to use both hands and quite a bit of force to get the wheels to budge even an inch.
