So we installed a 1991 front Dakota clip on the front of an old Dodge pickup frame. Ended up getting the rack hot tweeking part of the mount. Anyway, the rack leaks,and with the engine running, you can snap the steering wheel a few degrees and the steering wheel will keep spinning until end of travel. I looked at prices for a replacement rack at the local parts stores, and online at rock. Are there any ones to stay away from or are they all about the same? I have never changed a rack before, so any advice might help. Thanks.
