This is for my old 92 D250 2WD CTD truck. I can't seem to keep outer tie rod dust boots on it. I would like to try some poly boots if I could match them up.
The stud is 3/4" and the base is 1 7/8".
Any help would be greatly appreciated.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
