I have a 20', twin 5k axle Haulmark: was a deal that found me. Was not even considering an enclosed. Even though I agree that 24' is ideal, having worked with this 20' for two+ years I would suggest to not rule out this size if a deal were to present itself.
Primarily I haul C3/C4 Corvettes (1968-96) in it, but have done B and E Bodies too. With the Vettes, space is of no concern even with a winch set up in the nose. The E body is very livable, the B Body is tight but not the end of the world.
My suggestions beyond ones previously mentioned: I'd recommend an arched roof and bowed nose unit. The arched roof is a must if it snows where you are: flat roof will not allow the snow to "flow off". It will sit there- then will just hold water and corrode the roof. The bowed nose will give a slight bit more room. The flat roof/flat front units are cheaper. Hallmark and the like (more $$) are arched. Look for torsion bar 5k axles, not the leaf spring 3.5k ones.
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
