Never did cut open the filter on the Durango, but over the weekend I did cut open the filter on my Dart as the oil light started to flicker at idle whick it hadn't done before. Found all kinds of curd in there. Previous owner resurrected it after sitting for years before I bought it and I suspect dried out sludge working loose, and the above mentioned valve stem seals might be it's problem.
