My sender is mechanical, no electrical connections. Yes the ticking came on with the drop in oil pressure, and went away as soon as the pressure came back. I figured originally that something was getting clogged, and to drop pressure in the whole system my first thought was the pickup tube. Thought the bypass in the filter wouldnt allow clogging. Then I realized Ive never actually seen an oil pump fail, so I posted here for more info
