Mine has the shelf in the rear, swinging pick up and a trap door. Trap door attaches at the bottom rear of the tie rod tube. I run the level at the top of the tie rod tube. The pan has been run as low as 6 qts (actual level in the pan). Normally 7 qts in the pan. Attatched is the diagram sent to make the diaper.
Doug
