I've never had to jack the pistons out after knocking the tops off. Those must have been really stuck in there. On all of the locked up Mopar engines I've worked on the assembly frees up once I've knocked a couple of pistons out. If the engine was store with the heads on usually only one or two cylinders have open valves and rust in the bore.
