Are you sure it's not 319? 318 is an unusual grade.
319-T6 has similar strength to 356-T6 in sand castings.
Perm or semi perm mold will be a little higher.
Check out Matweb.com
Numbers will vary depending on the source
I believe 319 is less expensive.
'70 Swinger 340
'91 Dakota
'72 Challenger
'05 Ram
