The Hellcat blower is specific to the Hellcat heads, the bolt pattern is not the same as you Apache heads. You will have to look and see if they can be modified to work.
1975 Jeep Cherokee compound turbo 5.7 Hemi/6 speed AutoX/Drag/Street. 9.97 @ 140 slicks, 10.74 in autox trim
