Originally Posted By Frankenduster
The term "Wide Block" is not correct. The Poly series engine block is dimensionally similar to any 273-318-340 or 360 LA series engine.
Like DogDays wrote...."The block has exactly the same deck height as a 1968 318. It's just the configuration of the heads and intake manifold that make it seem farther between the valve covers."
Thank you
They say there are no such thing as a stupid question.
They say there is always the exception that proves the rule.
Don't be the exception.
