on my projects i used the front rotor off an f250 or dodge 250 on the rear----made a bracket to hold a lincoln mkVII rear caliper----it has cable e-brake---had to turn down the rotor to 1" which bothers some because that makes it worn out for a front brake-----speedway has several bracket options for the rear discs---the cheapest is the metric chevy rear....
