Originally Posted By MR_P_BODY
Originally Posted By WHITEDART
What I have been doing lately is rounding the edges on the camshaft gear itself
. And this process has greatly added to the life of distributor gear... a lot of times the cams have very sharp edges..
Are you talking a roller cam and bronze gear.. I have a
solid flat tappet and bronze gear.. I didnt have any
stock gears laying around so I uses a bronze that was
on the shelf.. it was new.. it has a couple hundred miles
on it
wave
you will be fine.. check out the cam see if the edge of the gear is sharp.if so just take the edge of
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
