It helps if you have a flywheel wrench designed for those converter, long skinny open end wrench
![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
If you reuse that type converter don't forget to reuse the star lock washers
Is your Power Wagon a stick shift? If so the six cylinder flywheel and starter will work on those early V8 with the correct truck bell housing, you may need to machine the crankshaft for a pilot bushing though
I put a 1957 392 New Yorker in my old 1955 Dodge D500 car hauler after the flathead six broke down the last time on the road, that engine swap made that a real truck
