Every once in a while though more and more often,when i turn the key to crank the engine on my 05 2500 ram nothing happens,,,try and try and try no crank..but if i use my aftermarket remote start truck cranks up as normal.Figured it had to be the ignition switch so installed new aftermarket switch and no difference,still wont crank with key but always cranks with remote start......
