Answer depends on how far you want to go with the upgrades. A lot of the lighter calipers have smaller piston area and would likely require booster/master upgrades + prop valve.
The 11.75 rotor and factory caliper works quite well with some performance semi metallic pads. That would be my suggestion if you want to keep it simple.
