I rarely get on these forums anymore because there is a lot of good info on fb. In the above stated group there is a guy putting 20lbs to a bone stock 5.7 hemi making 680hp to the tires in an a body. I'm finishing up the turbo system now on mine. Stock 05 5.7 hemi, cam, timing set and gapping the rings for boost then just going to see what it will take for boost.
Thanks. your setup looks clean. It's just difficult to go back and find posts on FB because it updates so frequently. 20psi sounds a bit risky on the stock rods, I assume he's running E85 or C16. I will try to find his posts.
