Untouched Eddie heads are a bottle neck on a 400+ cubic inch motor and will likely limit you to under 500HP. Add $1k for porting and retrofitting an older block for a roller cam will set you back $1500.
I wouldn't use cast internals to cut costs with your stated power goals either. Plan on spending $8000 then add another grand for incidentals.
1987 Fifth Avenue - 512/518/D60
