I'm building a local customer a pump gas 340 stroker motor with a cast steel scat brand crankshaft, Scat I beam rods and SRP pistons with Eddy RPM 65 CC heads (10.2 to 10.6 to 1 comp. ratio)and a Eddy RPM Air gap intake. I'm hoping for and expecting 480 to 500 HP with the local 91 octane non ethanol pump swill at around 6200 RPM with either 830 or 850 CFM carb, I have both sizes in stock. I will dyno test and tune it on the local Studka brand engine dyno, it will go in a 1966 dart GT with a 4 speed also
