I don't remember specifics for diminsions, but the Ford eyelet is larger and skinnier. This is a great time to make it from bearing bronze, and also replace the other pedal bushings with bronze while your at it. Pedal is oh so smooth now.
total width was .400, dont remember the rest
press fit bushing, then ream to .500. YOU NEED A REAMER, bushing shrinks when pressed in.
