Agreed, with the right speedo gear the ODO will automatically be corrected & most always then the magnetic gismo speedo will also be correct & if not then the speedo head in that rare case will need to be sent to a speedo specialty shop to be recalibrated (or another one at a boneyard may be cheaper).
