They were put on with a twist rivet from the factory and must have fallen out easily. I bought a AAR in 76 with a warranty replacement short block and one BOLT holding the pan on and the other OEM twist rivet laying in the oil pan with aluminum shavings and another spun rod bearing. It cost my AAR two motors!
