As of this morning........Steel split mono, Assassin bars and Menscer's new leaf spring valved shocks
This is the setup I'm going to use. So if I order CM tube how does one tell the difference between that and MS? I asked this question for the roll cage.when it's come time to cert the cage. Can you tell by looking at the metal that it's CM vs MS?
