Originally Posted By TC@HP2
In my experience on cars with unequal length A arms, high static negative cambers numbers are only necessary for softly sprung cars that generate a lot of body roll and/or race on flat surfaces. Also, the unequal length arms create additional negative camber gain as they compress, so a -1* static could translate into a -3* dynamic at 3" of suspension travel depending on your upper/lower arm ratio. Ultimately, your tire temps will tell you what it wants.
Taller spindles will create additional negative camber gain as will shorter upper arms or longer lower arms. Ways to achieve this with stock parts using stock mounting points would be to use A body lower arms, F body disc spindles, and Moog offset upper arm bushings.
All depends on how much effort you want to put into it and how competitive you really want to be. With a full hvac system and a fully insulated passenger compartment, this doesn't appear to be a maximum effort build. Based on some other builds I've seen on the interwebs, I tend to wonder if a truly stock suspension car can really be competitive in the cam classes on a national level at all, but admit some ignorance of the specifics of the classes. Look these for a cam t class car being built on site here; front - https://board.moparts.org/ubbthreads/ubbt...tml#Post2187270 and the rear - https://board.moparts.org/ubbthreads/ubbt...tml#Post2193251
I will add that 3º with stock mounting points is not needed. We run a tubular QA1 front which uses mostly stock mounting points and we roll out of the shop for competition at 2.1º camber, 6.5º caster and 0 bump. This is at 5¾" ride height, 18"/ 275 front tire.
Unfortunately, for us ambitious Mopar guys winning at a big national level event is a rarity and mostly garage talk (with a streetable B-body). If you can really wheel and there is some heat in the track, you can touch 8th to 12th most likely.
1968 Pro-Touring Dodge Charger
*2011 Optima Ultimate Street Car Challenge Invitee
http://www.popularhotrodding.com/features/1203phr_1968_dodge_charger/index.html
