The vast majority, okay nearly all, S and T rated tires are built on carcass designs that are over 25 years old. Very few true 15" street tires are even built on a newer design and speed rated carcass any more. MT SR, Maxxis Marauder, and Nitto are the few 15" tires that are decent anymore, and that is only relative since they aren't true UHP tires, but none of them come with RWL. So if RWL are important, the selection becomes limited to cosmetic performance...or you have to add an aftermarket white letter kit to them.
