Bored, need to look at mine and find out what's up with it. Deep freeze is setting in, so other than collect info on someone else's there is not much I can do....
Mine is 95mm. I cannot image them needing too much difference in jetting if the carb is the same size, but then again, I am not even remotely and expert on anything like carbs.
'70 Cuda,...605 EFI Hemi Street Car (6.20 best pass, 1.33 60ft)
https://www.youtube.com/watch?v=WYw6RA-k5Bk (6.25 at 108.75mph from inside car)
https://www.youtube.com/watch?v=3zQEb9uxFng (6.25 at 108mph from outside car)
'66 Barracuda AWB Stretched nose Blown 440 Car in build stage
'71 Duster Drag Car 400 Low Deck 512 best 6.002 at 115.44mph
https://www.youtube.com/watch?v=Znuo3jMUXTk
