Yep, that would do it. I wonder how the Trick Flows would compare to the std port SR heads.
I think the answer to the question is how fast will 700 hp go in your car. Obviously a 700 hp engine in a rail will go a ton faster than in an Imperial with street tires.
It is fairly easy to build a 700 hp std port engine these days. Buy some Trick Flow heads, add a solid roller cam and some decent compression and you are there.
