Yep, I know it's a grommet. Do you suppose it's the grommet for a breather or did Mopar have a PCV that was that big. I ask because there is one hole on each valve cover. One is the fill and the other had this grommet. Maybe the guy that had them before me didn't run a PCV.
I'm planning on using a breather that doubles as a fill and will need a PCV valve to go into the other side. I was just wondering if a Mopar ever used a PCV that was this big. Then I would buy that PCV.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
