Both Butting of the rings and or detonation can break the ring lands. With Detonation there is usually tell tale signs as in Specking of the pistons and quench pads. I cant tell from the pics if there is any specking because of all the scrappnel damage. But there could be. mike
Too tight of ring gap is a good point. The "good" pistons that are left in it (that didn't have any shrapnel hit them) don't show any signs of specks taken out of them. So the rings probably butted together, then?
