Originally Posted By Hot 340
Thanks guys. It doesnt look like there is no way to run double pumpers, so are you bigger cube guys running 750 vacuums with side hung floats?
Here is what the set up looks like. Again, be prepared to make your own fuel line. It gets pretty busy on the driver side with linkage, fuel lines and kickdown cable (Bouchelon) all crammed on one side and tucked under the Classic Haulage air filter!
