Re: very early block.
[Re: Dave Watt]
#219458
02/10/09 01:40 PM
02/10/09 01:40 PM
Assembly date of January I would question, January cast date would be OK. The casting plant would have produced thousands of blocks, it's possible to get shoved to the back and not used for a few months.
But the same holds true for an engine that is already assembled and on the "shelf" at the assembly plant. They were not concerned with stock rotation, especially in the middle of the model year. Stranger things have happened.
