As I had mentioned, the Drivetrain Sub assembly is coming together. I recently received the fuel filter from Dante and will need to install all the fuel lines from the pump to the carbs. I also still need to install the linkages for the carbs. The suspension is done but I still need to install the rotors and calipers. I'll change the air cleaner base to the correct one after I install the engine.
