The pump you want is a mid 80's to late 90's GM 3500 series diesel, it is a Saginaw pump with 2 return lines on the reservoir. Mounts the same as any other sag pump. You also don't need a high output pump, the brakes done use much volume. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
I didn't do 4 years and 9 months of Graduate School to be called Mister!
