I think I have 1st gear slipping but it keeps putting down new best sixty foot numbers. Currently running 1.15 to 1.18. But the motor does not drag down like it use to when you put it in gear. And it seems mushy putting it into the lights. It has about 100 runs on it lol. I adjusted it once a few years ago and went to adjust it again today and seem to have ran out of threads on the shifter tower.
Does anyone know what clutches and steals a CS1 lenco uses?
Also what should I set the clutch clearance too?
