I've found fedex ground to be less expensive than ups in most cases.
You can ship two iron heads in one box, if it's packaged well.
Last time I shipped heads, FedEx had the best rates on heavy and/or bulky items.
To put 2 heads in 1 box bolt them to a piece of 1/2" plywood or something similar so they can't shift around. Make sure the wood fits tightly in the box (or it defeats the purpose!).
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
