The car sits a little high at the back, at present, there's around 1" clearance from the front of the tyre to the wheel arch, as it is, i'm thinking if i lower it down it might rub unless i push it back a touch, what's the most i could realistically get away with. The springs are already moved into the rails.
Mr P, I'm having a new driveshaft made.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
